Audiobahn ABASS210P
Old Aug 10, 2004 | 06:54 PM
Badmash's Avatar
Badmash
Default Audiobahn ABASS210P
sup guys... im the guy mishima_beef was refering to about the 2 and 4 channel question... well, i just ordered a Audiobahn ABASS210P and i wanna know what kind of amp u think i should use to power it... and if u think the subs are any good.They are 700 Rms each and 1400 peak.
Heres the Picture
Old Aug 10, 2004 | 07:30 PM
saga's Avatar
saga
broke college kid
I definitely think that's a good set of speakers. Audiobahn makes good subs at a nice price. It's going to be hard to find an amp to put out that much power at 4 ohms though.
Old Aug 11, 2004 | 12:10 AM
tegryder23's Avatar
tegryder23
cgp dc4
I would have to disagree but thats from my personal experience with a friend of mine...audiobahn i sthe suxor
Old Aug 11, 2004 | 12:38 AM
saga's Avatar
saga
broke college kid
I've only heard good things about them. I don't have any of their speakers. But if you want a speaker that handles a shitload of power for a good price and want to be heard Audiobahn is the way to go.
Old Aug 11, 2004 | 12:05 PM
Badmash's Avatar
Badmash
well i just bought an amp Audiobahn A8000T Intake Series to power the twins.
Key Features:
Power Output: 4 ohms Mono - 400 watts x 1
Power Output: 2 ohms Mono - 800 watts x 1
Class A/B MOSFET Circuitry
PWM MOSFET Power Supply
Semi-double Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Variable 18dB Hi-pass Crossover: 50Hz - 750Hz
Variable 18dB Low-pass Crossover: 50Hz To 120Hz
Bass boost on/off
Subsonic Filter: 20Hz to 50Hz
RCA Throughput Connections
3-way Protection Circuitry: Thermal, Short Circuit and Overload
Cooling Fan
Cobalt Blue Illumination
High gloss Chrome Plated Finish
Nickel Plated Block Terminals
Air Induction Fan Cooled
RCA and Speaker Level Inputs
Optional ARB100T Remote Mount BASS BOOST CONTROL ($19.95)
1-year Sonic Electronix warranty
Amplifier Specifications:
Number of Channels 1 - Mono
RMS Power (4 ohms) 400 watts x 1 chan.
RMS Power (2 ohms) 800 watts x 1 chan.
RMS Power (1 ohm) Not Stable
Bridged RMS Power Not Bridgeable
Peak Power Output 1600 watts approx.
Min. Impedance Unbridged 2 ohms
Min. Impedance Bridged 4 ohms
THD @ Rated RMS Power 0.02%
Speaker Level Inputs Yes
Amp Preamp Outputs Yes
Built-in Crossover HP (50 - 750Hz), LP (50 - 120Hz), Subsonic (20 - 50Hz)
Bass Boost On/Off Switch, optional bass remote not included
Signal-to-Noise Ratio 100 dB
Fan Cooled Yes
Fuse Rating 30A x 2
Warranty 1-year SE
and the subs...
Product Description:
dual 10" ported bass box
high quality MDF construction
molded high glass front panel
spun aluminum Venturi port
high durability black fabric covering
chrome flame grilles
PHAT foam surround
dual 12" non-pressed, non-transfer paper cone
molded texture injected poly cone
45oz strontium magnet
2" layer ASV voice coil
bumped back plate
extended & vented pole piece
gold binding post terminals
Subwoofer Specifications:
Subwoofer Size 10"
Impedance 4 ohms, 1 pair
Dual Voice Coil No, 2 single voice coil inputs
Peak Power Handling 1400 watts approx.
RMS Power Handling 700 watts
Surround Material PHAT foam surround
Sealed Box Volume N/A
Ported Box Volume N/A
Sensitivity 92 dB
Frequency Response 28 - 1kHz
Top Mount Depth N/A
Cutout Diameter N/A
Warranty 1-year SE
Old Aug 11, 2004 | 03:53 PM
importkustoms00's Avatar
importkustoms00
Korean DOOD
audiobahn sux
Old Aug 11, 2004 | 08:03 PM
Badmash's Avatar
Badmash
Originally Posted by importkustoms00
audiobahn sux
audiobahn is amazing wat u talkin bout... top of the line subs rite here
Old Aug 11, 2004 | 09:06 PM
tegryder23's Avatar
tegryder23
cgp dc4
Hey come back in like 6 months and tell us if u still have those things. Audiobahn does suck big time and yeah they can handle a lot of watts but they won't hold up at all, not even half the time as say ALPINE OR PIONEER, KENWOOD etc...
Old Aug 11, 2004 | 09:50 PM
Badmash's Avatar
Badmash
:sad:
