Rear Deck Speakers
how do i take em off on a 96 civic coupe?
I pulled them off my 94 Sedan. I can't imagine that they're too different. You get in the trunk and look up at the trunklid. You'll see a set of three bigger screws which actually hold in the speaker grilles. Remove those, then loosen the three screws right around the speakers, unplug, and voila, the speaker comes out from the inside of the car. They are actually really easy to remove.
mines have self tapping screws, i think..
all this to remove speakers??!!
in step 2, is it the carpet in the trunk or.... are pics available?
No pics available... sorry.
yep....all that to remove the rear speakers.
In cliff notes version: Remove backs of rear seat, then remove bottom, remove side pannels(few screws on the bottom, seatbelt bolts, and clips) then remove top deck.....speakers then lift out once unscrewed. |
In cliff notes version: Remove backs of rear seat, then remove bottom, remove side pannels(few screws on the bottom, seatbelt bolts, and clips) then remove top deck.....speakers then lift out once unscrewed. how long should this take? and by bottom do u mean basically the whole back seat? |
basically, yeah, the whole back seat. Can be done in well under an hour.
Dont cut corners. you'll break plastic parts and its really sharp, plus expensive to replace....most stuff inside the 6th gen civics requires surronding piece removal to take out....it kinda all fits together like a puzzle to hold everything tight |
