so.....
i know i've asked this a million times, but i'm so frustrated by it..no one can help me..so i'm asked one last time
i got a led light i want to wire to my car. when the key if off the light goes on. it has a pos. wire, neg. wire, ground wire, and white wire which can hook up to ignition. I tried hooked up the pos. and neg. to my cig. lighter ( which i thought was always constant) but that didnt work, b/c the light only came on when the key was on. ......and i'm not going to wire it directly from the battery. so yeah.....someone told me remote line i can use for a hook up, but i only thought that remote line to the amp worked when the key was turned on.. so can someone tell me how to do this all...probably so freaking easy.! :eek: |
do u have a secuirty system already installed? if so you can use that.
what car is this? year model?
get a relay, SPDT relay from www.partsexpress.com 89cents each wire it in this order: 85-ground 86-acc wire or ignition 30-one of the wire (the other one ground) 87a-12volt constant. this way, the LED will turn on when key is off, on when key is on. good luck!!! |
