Is There Anyway To...
Old Apr 14, 2004 | 06:11 PM
half_way_grown's Avatar
half_way_grown
Default Is There Anyway To...
on a pioneer cd changer there is the ground wire the i-bus plug that you hook up to the cd player and the wire wit a fuse that you hook up to the battery i am missing the top part of that wire the part the closes the fuse so i am stuck wit a fuse that i can not use and i can not hook the cd changer up to the battery is there any other way to hook it up
Old Apr 15, 2004 | 06:00 AM
TTT's Avatar
TTT
Ok, I really don't know what your problem is (punctuation and correct grammar may help abit) but you can go buy another fuse holder, cut off your old one and hook it up to the wire that you just cut. Then you can get some 12 or 14 gauge wire and run it back to your battery if you want. I don't see the point in running it all the way to your battery though... grounding it on the chassis is basically the same thing. Also, why do you have a fuse on the ground wire? You sure its not the positive power wire?
Old Apr 15, 2004 | 08:00 AM
half_way_grown
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW on the battery wire i only have the part that says 2A on it if that helps
Old Apr 15, 2004 | 08:06 AM
john666's Avatar
john666
Drive it like u stole it.
Can't you Just go to radio shack and buy a fuse holder and cut and put it in ?
Old Apr 15, 2004 | 10:40 AM
TTT's Avatar
TTT
single post
TTT's Avatar
TTT
double post
TTT's Avatar
TTT
triple post
Old Apr 15, 2004 | 10:41 AM
TTT's Avatar
TTT
Or you could do what I said and buy a fuse holder, cut the old one off and put the new one in h:
