Need help/pics with EG rear speakers
I just picked up some rear speaker brackets for my 93 DX hatch. All the holes on the brackets match those on the panels in the car. However, the brackets won't quite fit in the correct space, resulting in the holes not lining up. What's the deal? Does something need to be modified? Everything I am working with is OEM. Might I have picked up coupe brackets by mistake? Can you post a pic of your EG rear speakers with the cover panels removed? That might help significantly. :confused:
Thanks for any and all help! |
this is the same for my rear speakers. i ended up using 2 of the 4 holes to mount the speaker.
you can create a baffle, but you might have clearance issues with the speaker cover. |
Anyone have any other ideas or insights?
Anyone?
this is what i did with rear speakers in my hatch
http://www.imagestation.com/picture/...c/fdacf92b.jpg |
did that pic help any?
Thanks for the pic. Its not really what I had in mind, but it does give me an idea or two.
the stock rear speaker mounts (if u find them, b/c they run at a high price) are only 5 1/4 those in my car are 6x9s
mine happen to fit perfectly. I had printout of the directions straight from honda so I had no problems. I'll post pics when I get home.
As long as the speaker is securely mounted, it doesn't matter if you use fewer than 4 screws.. Good luck!
