barely anything coming from sub
Old Jan 23, 2004 | 09:27 AM
narc's Avatar
narc
Default barely anything coming from sub
after hooking up my sub/amp i can barely hear anything from the sub. i an tell its on and the amp is working, but no sound. any advice?
alpine 1241-d type-r 12"
jbl px600.2
Old Jan 23, 2004 | 12:35 PM
KuttinEdge's Avatar
KuttinEdge
Check the ground wire. The power lights on the amp may be on, but the ground may not have a good enough connection to power the subs. The ground has to be REALLY good (almost have to connect directly to the neg terminal on battery).
Old Jan 23, 2004 | 03:01 PM
narc's Avatar
narc
everything is connected well but still barely any sound.
Old Jan 23, 2004 | 04:30 PM
billscivic00's Avatar
billscivic00
Is your sub new or is it used? if it is used, it might be blown.
Old Feb 12, 2004 | 06:50 AM
mossman's Avatar
mossman
Mark
jbl px600.2
If the equip is used, I would suspect that it doesn't work. If new, make sure that you have the settings on the amp correct. Gain UP, low-pass crossover ON. To check the speaker. Take a 9V battery and tap the wires on the speaker terminals. If you hear a loud pop/crackle, speaker is probably not blown.
