Sub/Amp question
Old Dec 27, 2003 | 12:58 PM
Tulo's Avatar
Tulo
Default Sub/Amp question
Hello. I have a DEI Studio 3124 12" 400w RMS 4 OHM single VC sub-woofer and I need to get an amp for it. Would it be best to get an amp that is also rated at 400w RMS? Right now i'm looking at the Rockford Fosgate Punch 401S. It's bridged RMS power is rated at 400w x1. Would this be a good match? Thanks. -JP
Old Dec 27, 2003 | 03:57 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
Old Dec 27, 2003 | 09:25 PM
Tulo's Avatar
Tulo
Old Dec 27, 2003 | 11:11 PM
5thgenAccordEX's Avatar
5thgenAccordEX
The Italian
is it rated 400W RMS at 4 ohms?....if so then you should be ok...even if not, that amp should still be fine, just know the limits of your sub!
Old Jan 4, 2004 | 05:00 PM
Rycechyk's Avatar
Rycechyk
Sounds pretty good.
I am running 2 300 watt JL subs off a Rockford Fosgate Power series 451s amp, and even that does a decent job, though the subs could definitely take more.
But yours, nice match.
Old Jan 4, 2004 | 05:07 PM
Shore 96 Teg's Avatar
Shore 96 Teg
I miss my 93 VTEC Lude :(
i would try to go right smack dab between the RMS rating and the peak rating of ur subs. Take me for example. I am running 2 Alpine Type E's (200 RMS 600 Peak) with an Audiobahn 800 watt mono amp at 2 Ohms. 400 to each. The subs slam and dont distort at all.
