Engine Interference Noise??
Old Dec 10, 2003 | 08:00 AM
Brett2000EX's Avatar
Brett2000EX
Default Engine Interference Noise??
I just had a friend install a new indash DVD Player/CD/TUNER and when the radio plays or CDs play I can hear the engine interference noise, Does that mean when he put it back in the wires are to close togther or whats the best way o correct this?? Thanks!!
Old Dec 10, 2003 | 11:02 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
more specs on system.
my guesses......
1.(assuming you have amps)use BIG ground wires and keep them short! 8guage min from the amp, 4 if allowed, or what i do, 8guage from the amps to a dist block, then 4 guage to the nearest point of ground.
2. always run cables with like cables in car. you have 2 options:
first, run rcas and speaker leads on side oposite battery, and then run power wire and amp turn on on side of car that the battery is on.
second, *best* RCAs down the middle of car(requres moving carpet/seats) speaker leads on side a, power on side b. worst case, you can run speaker wires from amp to power side speakers on that side, but avoid if possible.
next, RCA's are KEY! expect to spend atleast (Very Cheap)$20 each rca cable. Mine were around $120 for each RCA cable but they really do make a difference. A lot of times, you can bargain with audio shops for wiring and RCAs when you buy a head unit/amps. They have markup in cases like that to cover installs and wiring. As to the ground wire, just buy some wire at radioshack for that. expect $1/foot or so....2+ for thicker wire.
Last. Run good speaker wire that is 12 guage or better.
Hope that helps!
Old Dec 10, 2003 | 01:05 PM
Brett2000EX
Well none of the wires have been changed, All I did was swap the headunits, I had a Clarion and then changed to a headunit that also played DVDs and I never had this issue till I put the new one in
Old Dec 10, 2003 | 01:09 PM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
does it have an external "brain"? if i were you, i'd check all the grounds, and maybe reground the wire from the deck solo instead of through the harness.
Old Dec 11, 2003 | 06:09 AM
Brett2000EX
It has an external amp, is that the same??
Old Dec 11, 2003 | 06:32 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
see above then. make sure there are good rcas from that to the amp, and ground very well w/ big ground wires.
Old Dec 11, 2003 | 07:16 AM
Brett2000EX
Thanks so much!! I will try that!!:thumbup:
Old Dec 11, 2003 | 09:01 AM
Surfacing171's Avatar
Surfacing171
cb7 fanatic
:thumbup: That should be like the golden rule of car audio.
