Those with knowledge of CLIFFORD!!!
If a window is scored, a spring loaded punch can be used to crack the glass with practically no shock.
The duck tape also softens the "blow" and catches all the glass.
94uhkord
which glass break sensor do you suggest?
any idea on how to hook it upto that AG4 of mine?
94uhkord
does duct tape work as tint? if have tint and someone tries to break it, will it make less noise and shock? i haven't tinted my windows cuz it's hard for ppl to look in in dark, so my neighbors won't be able to see $hit if someone breaks into.
cause it's tight!
94uhkord
94uhkord
so the omnisensor is better then the dual shock, and if anyone tryies to greak in with a spring loaded punch and duck tape, the proximity sensor will get them. so does that about cover the car?
now i just need a very good good lock.
cause it's tight!
Clifford glass sensor is plug and play with a harness from the sensor control to the alarm brain. The mic is connected like an rca plug. Simple and every alarm should have a glass sensor.
94uhkord is right about the glass punch tip. You can in fact break out a window without setting off a shock sensor, or omni sensor. I work with a professional car thief and security consultant who has defeated almost every single alarm we have encountered on the market. Where there is a will there is a way.
arch iceman, do you sell alpine alarm stuffs? if so, can you give me a quote with approx. installation costs on the following stuffs?
i ask this, cuz i feel that i got scammed pretty bad. you can PM me and i will PM back for the price i got. thanx
btw, is Alpine alarm any good compare to high end Clifford's?
Alpine Sec-150r
clifford digital tilt senor
shock sensor
hood/trunk pins
priority unlock
keyless entry/trunk release
flashing lights
one backup siren
3 point kills(i have chip in the key, so fuel kill is needed)
Alpine Sec-150r
shock sensor
hood/trunk pins
priority unlock
flashing lights
one backup siren
