Problem with idle speed??.....really wierd problem
Old Oct 1, 2003 | 03:34 PM
Mike Oxbigger's Avatar
Mike Oxbigger
Default Problem with idle speed??.....really wierd problem
When i'm in neutral and my a/c is on, i hear a clicking noise in the engine bay that engages every 5-10 seconds. When the clicking sound happens my idle drops to a little lower than 500rpm and the car shakes like hell. It reminds me of when you leave your car in gear by accident sometimes and brake w/o hitting the clutch. Also, when idle speed drops, the electrical systems dim.
However, when i'm in neutral w/o a/c the car is fine and idling at 725rpm.....my haynes manual says the car should idle between 650-750rpm. A friend said i should just adjust the idle speed to go higher but won't that mess up my engine?
Old Oct 1, 2003 | 03:35 PM
Mike Oxbigger
oh yeah.....the car is a 96 manual accord sedan
Old Oct 1, 2003 | 05:05 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
kind of sounds like the AC system is overcharged. If thats true, the compressor will be shot as well, thats the clicking noise.
Does your AC work? If its not very cold, have a professional check it out.
It really sounds like the compressor is shot though.
Old Oct 1, 2003 | 05:43 PM
Mike Oxbigger
the a/c works but i have to admit that its not putting out the cold air it used too
Old Oct 1, 2003 | 07:41 PM
SumAccordGuy94
Older Honda Fanatic
it will work a little... but being the compressor is cycling on and off really quick like that, that means there is too much pressure in the system... and from that, the compressor will be pretty much dead now... thats the clicking noise.
