5 speed conversion
Old Sep 24, 2003 | 11:39 PM
RyanBabcock's Avatar
RyanBabcock
Default 5 speed conversion
i want to convert my auto trans to a manual trans. i drive a 95 accord lx (f22b2). what all do i need and much will it cost.
Old Sep 24, 2003 | 11:41 PM
Nelson's Avatar
Nelson
Administrator
Not sure on Accords, but it's fairly inexpensive and easy for Civic's...
Well worth it IMO. But, I would might as well swap out the motor along with a manual tranny to make it worthwhile.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Sep 24, 2003 | 11:48 PM
RyanBabcock
i don't got the money for the h22a and my engine has low miles. i just want a manual trans
Old Sep 25, 2003 | 07:49 AM
proteus's Avatar
proteus
might be more worthwhile to trade you auto for a manual, than to do the swap.
You will need manual tranny, ecu, shift linkage, shifter, clutch pedal assembly, clutch master and slave cylinder. Maybe axles. You will need more than that. It will probably be cheaper to sell and get a manual accord.
Old Sep 25, 2003 | 10:30 AM
92lx
Guest
Posts: n/a
rather cheap and relatively easy, you'll need to do a little welding and such, it probably would be easier to do it with an h22 swap, or if you're not going to do that, just trade for a manual accord.
- Nathan
Old Sep 25, 2003 | 02:20 PM
AKUFC's Avatar
AKUFC
PANIC NOW!!!
You don't have to get the manual ECU.
You wouid need a tranny, driver side axle, and jackshaft/intermediate shaft off a 5spd accord, clutch pedal assembly, brake pedal, Clutch Master cylindar, shifter and cables, clutch, flywheel, and the flywheel bolts, 5spd console(just where the shifter is) clutch hardlines.
http://www.extremeredline.net/accord/automanual.html
- Nathan
What would he do with the down time of having no car after he sells it? Selling your car than finding a 5spd isn't a overnight procsess.
Old Sep 25, 2003 | 04:25 PM
A_D's Avatar
A_D
Reset?
the swap with all the parts and the tranny costs about the same as the h22 does. if you're doing the labor and buying the parts yourself
Old Sep 25, 2003 | 06:36 PM
AKUFC's Avatar
AKUFC
PANIC NOW!!!
Umm if he buys a h22, how would he get the transmission in if he spent that on the motor?
Old Sep 26, 2003 | 06:01 PM
Nelson's Avatar
Nelson
Administrator
That is true.
- Nathan
:thumbup:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
