My Accord's Windows Acting up~ need ur help
I have a 96 Accord LX Coupe. Recently the passenger side window started acting up. The power window switch from the passenger side works perfectly but the power window switch from the driver's side won't let me close the passenger side window. But I can still bring it down but doesn't go up. What do I need to do? And how much should I expect to pay for the repair? Thanks so much for all ur help. :)
just clean the track the window is in. I heard that silicone or armor all sprayed in the track will help it go up and down more smoothly. I had the same prob.
if only one side doesnt work, i would replace the switch that is inop. try a junkyard, i had the same problem on a 91 accord, but it was the pax side that was inop. 10 bucks at the junkyard, one screw and a connector and i was in business. yours may be more if you have to replace all 4 window switches as an assembly.
| All times are GMT -8. The time now is 05:05 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
