check engine light fault trouble codes list
I found this on the net so I don't know if it's correct or not.
Before you can start reading the CEL (check engine light) in your dash, you need to 'jump' your ecu. Here's how. Located the factory two-pin connector of brown and black wires near the ECU on Civics del Sols and Integra's, or behind the center console for Preludes and Accords. Pull that 2-pin out of the main harness. Using a wire or paper clip as a jumper, connect the outputs of the harness together, so that the black wire and the brown wire make a circuit. Once this is jumped together, the dash will start the light show, so its a good idea to jump first, then turn to on. For 88-91 Honda's and 86-93 Acura's: The ECU's on these cars actually have a neat little window right on the computer case. No need to jump here- just turn it to on, and watch it right there through that window. For both steps above, the output will be in a Morse code style of long and short lights. Every long equals 10 and each short is 1. For example, 2 long and 3 short is 23. 1- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor 2- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-89 86-87 n/a 85-87 85-91 n/a n/a Oxygen Sensor "B" defective circuit or unplugged / defective sensor 3- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor 4- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-98 88-98 97-98 88-91 93-97 95-98 85-98 CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor 5- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 * 86-98 97-98 85-91 93-97 96-98 85-98 MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping * exc 94-95 6- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor 7- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 TP Sensor (Throttle Position) defective circuit or unplugged / defective sensor 8- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor 9*- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98** 86-98 97-98 85-91 93-97 95-98 85-98 CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor * not a valid code for any throttle body injection Hondas ** not a valid code for V-6 engines 10- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor 12- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 * n/a 85-91 * n/a 95-98 85-98 EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor * not a valid code if car is not equipped with an EGR valve (some Civic models are not) 13- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor 14- Accord Civic CRV CRX Del Sol Odyssey Prelude 88-98 88-98 97-98 88-91 93-97 95-98 88-98 IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor 15- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-95 88-95 n/a 88-91 93-95 95 88-95 Ignition Output Signal missing or defective ignition output signal 16- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-95 88-95 n/a 88-91 93-95 95 88-95 Fuel Injector System defective circuit or unplugged / defective fuel injector 17- Accord Civic CRV CRX Del Sol Odyssey Prelude 88-98 88-98 97-98 88-91 93-97 95-97 88-98 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor 19- Accord Civic CRV CRX Del Sol Odyssey Prelude n/a 88-95 n/a 88-91 93-97 n/a n/a Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve 20- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-98 88-98 97-98 88-91 93-97 95-98 92-98 Electrical Load Detector defective circuit or unplugged / defective sensor 21*- Accord Civic CRV CRX Del Sol Odyssey Prelude 94-98 ** 92-95 n/a n/a 93-95 n/a 93-95 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve * not a valid code if car does not have a VTEC engine ** not with V-6 engine 22*- Accord Civic CRV CRX Del Sol Odyssey Prelude 94-98 92-98 n/a n/a 93-97 98 93-98` VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch * not a valid code if car does not have a VTEC engine 23- Accord Civic CRV CRX Del Sol Odyssey Prelude 98 * 96-98 n/a n/a 94-97 n/a 92-98 KS (Knock Sensor) defective circuit or unplugged / defective sensor * not a valid code if V-6 engine 30- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-98 * n/a n/a n/a n/a 95 92-98 * Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB defective circuit or unplugged / defective sensor * not a valid code for 1996 31- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-95 n/a n/a n/a n/a 95 92-95 Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor 41- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-98 92-98 97-98 n/a 93-97 95-98 90-98 Primary Oxygen Sensor - Heater circuit malfunction 43- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-95 92-95 n/a n/a 93-95 95 90-95 Fuel Supply System defective or malfunctioning fuel supply system 45- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 System Too Lean or Too Rich malfunction in the fuel monitoring systems 48- Accord Civic CRV CRX Del Sol Odyssey Prelude 98 92-98 n/a n/a n/a n/a n/a LAF Sensor (Lean Air Fuel) defective circuit or unplugged / defective sensor 54- Accord Civic CRV CRX Del Sol Odyssey Prelude 96 96-98 97-98 n/a 96-97 n/a n/a CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor 58- Accord Civic CRV CRX Del Sol Odyssey Prelude 98 * n/a n/a n/a n/a n/a n/a TDC Sensor 2 (Top Dead Center) defective circuit or unplugged / defective sensor * with V-6 engine only 61- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response 63- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response 65- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater 67- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system 70- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a n/a 96-98 96-98 Automatic Transmission malfunction with the automatic transmission controls 71- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire 72- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire 73- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire 74- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire 75- Accord Civic CRV CRX Del Sol Odyssey Prelude 98 * n/a n/a n/a n/a n/a n/a Cylinder 5 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire * valid code for V-6 engine only 76- Accord Civic CRV CRX Del Sol Odyssey Prelude 98 * n/a n/a n/a n/a n/a n/a Cylinder 6 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire * valid code for V-6 engine only 80- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 n/a n/a n/a 96-98 96-98 Exhaust Gas Recirculation insufficient flow detected 86- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem 90- Accord Civic CRV CRX Del Sol Odyssey Prelude 97-98 96-98 n/a n/a n/a 98 97-98 Evaporative Emission Control System leak detected in the fuel tank area 91- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 n/a n/a n/a 98 97-98 Fuel Tank Pressure Sensor low input 92- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-97 96-98 Evaporative Emission Control System insufficient purge flow I found this on the net so I don't know if it's correct or not. |
Some details have changed over the years. The connector on my '95 Integra is buried up between the glovebox & the right kickpanel. Our '98 Accord doesn't seem to have that connector, but it's got an OBD-2 connector (for a scan tool) left of the steering column.
I didn't look thru the entire list, but the couple I glanced at looked consistant with my cars. |
anybody know exactly where the 2 pin connector is on a '92...cuz behind the center console is a bad spot...gotta take out center console and then the trim right?...and the trim has a ton of screws
where did you get this information? and for codes 21, 22, and 23....when you mention the 98 accord, do you mean the 6th gen or the 5th gen?
98 = 6th
Originally posted by AngryNerdRock where did you get this information? and for codes 21, 22, and 23....when you mention the 98 accord, do you mean the 6th gen or the 5th gen? Please don't ask "do you mean" because as I said when originally posted, I didn't write it and don't know if it's correct I just posted it because I hoped it would help others. |
Originally posted by uclaccord 98 = 6th |
I have a CEL on an '88 Accord LXi. The car runs great, but it comes on and stays on until you turn the car off and restart it. Then it stays off for awhile and comes on again.
1. Does any one know here to pull the codes for it, where is the connector? 2. What are the codes? Where can I get them? 3. It just passed emissions inspection with flying colors, so it couldn't be the O2 sensor could it? 4. In the book it says it's the injection system. It runs fine though. |
Originally Posted by jaffydude
(Post 3084164)
2. What are the codes? Where can I get them? When we had the '90 Accord back then and I was troubleshooting this, I found a PDF file (don't remember where) that contains the information you've asked (where the connector is, how to read the codes, and what the codes mean). I just checked my files and it's still on my computer. I'm willing to share this but a PDF file attachment is not allowed here. I tried to save it to a ZIP file, which is allowed here, but it's 1.1 MB and that's too big to be uploaded. If someone knows how I can upload this somewhere I will post it but I'm not willing to send it out via email to the many many many requests that I know I'd get (so don't even ask), that would just take too much time/effort. Let me know where I can post it for download and everyone can get it. |
uplaod it to rapidshare.de, or yousendit.com
