Fan doesn't come on anymore
Old Sep 15, 2003 | 10:51 AM
gnehc1's Avatar
gnehc1
Default Fan doesn't come on anymore
Can someone tell me what else i should do? the fans on my 91 accord don't come on anymore. i replaced the cooling fan relay (inside the fusebox under the hood) and it still doesn't come on after i drive for some time. it used to come on and off while driving and come on after i turn off the car. any suggestions? if it matters at all, i had my radio stolen about 2 months ago and ever since then it hasn't worked.
thanks...
Old Sep 15, 2003 | 12:43 PM
jschmid's Avatar
jschmid
Fuse (in my 99 it's under the dash), relay (which you already checked), temp switch, fan motor, thermostat.
There's some possibilities anyway.
Old Sep 15, 2003 | 01:15 PM
gnehc1's Avatar
gnehc1
the fan does work, i wired one of the prongs of the relay to ground and it spins when the ignition is on "ON" but i don't want to have it on all the time, just when it needs to.
but i'll check the fuses and other things you mentioned. when my radio was stolen, the lines probably crossed and shorted the fan. thanks for the reply
Old Sep 15, 2003 | 01:31 PM
JimBlake's Avatar
JimBlake
You could jumper the plug for the fan switch, make sure the fan runs. If that makes the fan run, then you've narrowed it down to the fan switch.
It's located in the thermostat housing on my '98, but I think they changed the location sometimes?
Old Sep 15, 2003 | 02:10 PM
4thGenRyder's Avatar
4thGenRyder
It could be the thermo switch.
Old Sep 15, 2003 | 05:35 PM
gnehc1's Avatar
gnehc1
does anyone know where the fan switch is located on a 91 accord???? thanks all...
