Car Alarm shock sensor..
Old Sep 14, 2003 | 10:22 PM
AccordManiac's Avatar
AccordManiac
Korean Member
Default Car Alarm shock sensor..
I have the car alarm installed and purchased optional
shock sensor.. Where should I install it?
Thanks.
Old Sep 15, 2003 | 01:37 AM
AccordManiac
Korean Member
bump^
Old Sep 15, 2003 | 01:22 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
you can put it anywhere as long as you have wire long enough should be 3 wires attached to it...
[alarmbox]=========={shocksensor}
IMO would put under the dash like everyone else.
Old Sep 15, 2003 | 10:51 PM
AccordManiac
Korean Member
Thanks.. how does shock sensor work?
Old Sep 16, 2003 | 11:49 AM
pirate252's Avatar
pirate252
I have mine up under my steering column, and it probably works by an elecromagnet of some sort, so whenever it moves it will go off, but for some reasn these (or at least mine) doesnt detect sway (shakin the car back and forth) i can shake it so hard the supsention bottoms out, but if i tap on the body panels, it goes of, its nutz.
