5th gen gas tank siphoning
Old Sep 13, 2003 | 01:10 PM
Funkwheat's Avatar
Funkwheat
Default 5th gen gas tank siphoning
My 94 Accord Wagon is dead right now, and I have no intentions on fixing it real soon, cause I have my 99 Accord now... However, when it died, I had almost a full tank of gas, and I'm a cheap bastard, and I wanna use the gas in my other Accord. Is there any easy way of getting the gas out that anyone knows of? I've tried siphoning with a bulb and a hose, but I had no luck... Any help would be appreciated.
Old Sep 13, 2003 | 01:26 PM
Samson's Avatar
Samson
chris is the devil
putting a tube inside, and sucking on it making it flow doesnt work?
Old Sep 13, 2003 | 01:41 PM
jschmid's Avatar
jschmid
Default Re: 5th gen gas tank siphoning
Originally posted by Funkwheat
I'm a cheap bastard
You aren't kidding.
Old Sep 13, 2003 | 01:52 PM
Funkwheat's Avatar
Funkwheat
As far as I know, that car is "siphon proof", which I guess means it has some kind of valve or something that prevents siphoning. Tell me I'm wrong please, though, lol.
Old Sep 13, 2003 | 10:01 PM
accordvtec77's Avatar
accordvtec77
if you actually LOOK at the bottom of the fuel tank...it has a drain plug. I'm NOT kidding....there is a drain plug at the bottom of my tank.
Old Sep 13, 2003 | 10:16 PM
Samson's Avatar
Samson
chris is the devil
i think your seeing is the trunk drain plug...... under the spare tire... there is a plug.
Old Sep 14, 2003 | 09:37 AM
Funkwheat's Avatar
Funkwheat
So is there a way?
Old Sep 14, 2003 | 10:24 AM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
go get some fuel stabilizer, add it to the tank fo the dead accord, then take ur cheap ass to the gas station and fill up the new accord ya cheap bastid:fawk:
Old Sep 14, 2003 | 10:50 AM
slo_accord's Avatar
slo_accord
There should be a drain plug on the bottom of the fuel tank. You need to disconnect your battery, relieve the fuel pressure, jack your car up, ground your gas tank... basicly a bunch of crap to get gas that is going to be filled with dirt and contaminants from the bottom of the tank. Just go out and buy some gas.
Old Sep 14, 2003 | 05:38 PM
Funkwheat's Avatar
Funkwheat
Note the key word there. Thanks for the help though. =)
