PGMFI Relay??? Problem, need help
Old Aug 22, 2003 | 08:51 AM
bryantr6's Avatar
bryantr6
Default PGMFI Relay??? Problem, need help
I'm having problems with a 93 accord ex, if you start it and turn it off right away it wont start again. After about 30 mins it will start again(when i'm lucky). I had someone look at it and he seems to think it the PGMFI relay. Any ideas???
Old Aug 22, 2003 | 10:53 AM
hype8912's Avatar
hype8912
Dr. Klaw
This was covered before on here. Its like some type of main relay on the left end of the dashboard. It will cost about 30 to 40 bucks for the relay. These are notorious for going out on 4g's.
Heres a link I found on it.
http://www.markl.force9.co.uk/howto/...main-relay.htm
Old Aug 22, 2003 | 12:47 PM
bryantr6's Avatar
bryantr6
Default Thanks
Thanks man, I've heard that from a couple other people too. I'll change that turd out and see what happens.:thumbup:
Old Sep 18, 2003 | 11:10 AM
speedyJ's Avatar
speedyJ
Could you tell me where this relay is located on a 92 Accord? My Chilton manuel only goes to 91. It is not behind the fuse box. I have heard it is behind the cruise but exactly where and wether or not it was the dash on/off cruise switch. Thanks
Old Sep 18, 2003 | 11:39 AM
BustedLX's Avatar
BustedLX
Rice Rocket
You have to remove the cruise control computer and it's right above it. It's like a gray with orange/brown color square box.
They retail for about $57 at your dealer.
Old Sep 18, 2003 | 04:46 PM
speedyJ's Avatar
speedyJ
Great! I'll give it a try in the morning.
Old Sep 19, 2003 | 01:13 AM
bryantr6's Avatar
bryantr6
I changed out the part about two weeks ago, I havent had a problem since.
Bryan
