new front control arms
Old Aug 12, 2003 | 11:30 AM
A_D's Avatar
A_D
Reset?
Default new front control arms
does anyone know if new front control arms for the 5th gen accords exist? like the skunk2 aftermarket control arms with the adjustable positioning ball joint and shit. or just a shorter control arm in general. i have a set of spc control arm anchor bolts for camber and consequently those pushed my control arms out and now they knock the fenders, and my left side ball joint is completely ****ing toast, just ****in trashed.
i need to bring my control arms in so they won't hit the fender.
anyway, thanks
Old Aug 12, 2003 | 11:38 AM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
try www.tasautoparts.com
Old Aug 12, 2003 | 01:05 PM
TypeSH's Avatar
TypeSH
so far, no aftermarket full control arm. There is an adjustable ball joint, believe its also made by SPC and u press out the old joint and the new one in.
I doubt they can make a shorter one because the knuckle has to attach at a certain spot/angle or else your suspenion is going to be all wack.
Old Aug 12, 2003 | 04:09 PM
A_D's Avatar
A_D
Reset?
well thats gay as ****
guess i'm getting my fenders cut/rolled so the control arm can have clearance
i put the spc control arm anchor bolts on and they pushed my control arm out, which makes it now hit the fender.
guess i'll just have to buy new control arms, the stock ones, and put the offset ball joints in there, and use my stock anchor bolts.
**** this sucks.
Old Jun 18, 2004 | 10:22 AM
Camberman's Avatar
Camberman
Default NEW - Adjustable Accord Control arm from Ingalls!
http://www.ingallseng.com/new_products.htm
Old Jun 18, 2004 | 10:41 AM
IamNemo's Avatar
IamNemo
You know me...
Just get a shop to take off a little bit of your control arm...the part that hits...unless it ALL hits...
