SPC camber kit question
Old Jul 24, 2003 | 09:09 AM
A_D's Avatar
A_D
Reset?
Default SPC camber kit question
i'm assuming how i install this thing is that i pop out the ball joint on the control arm, and then install the kit through the hole where the ball joint was (having the anchor bolt through that hole) and connect the tie rod arm into the kit?
just want to make sure because on the instructions it says "remove the stock anchor bolts" so i'm like...hmmm...
if anyone can clear it up for me it'd be much appreciated. thanks
Old Jul 25, 2003 | 07:08 AM
v4lu3s's Avatar
v4lu3s
you typically need to take th upper control arm in and have the ball joint presed in and out.
Old Jul 25, 2003 | 08:29 AM
A_D's Avatar
A_D
Reset?
nm i figured it out
the anchor bolts for the control arm are what these replace
