washer trick/alignment help please
Old Jun 26, 2003 | 11:46 AM
A_D's Avatar
A_D
Reset?
Default washer trick/alignment help please
i did a search on the washer trick thing and it looked like i have to know the exact degree's of my off-alignment to know what kind of washers and bolts i need to buy. so what i can tell you is the camber on the left rear is 1.5 degree's off but i don't know the toe in. and i don't know either for the right rear. i'm going to the tire shop right now to find this out. so i'll be back in like 15-20 minutes and i'll post the results in this thread. if somone can help me with what washers and bolts i need to buy to align my rear end, i'll be forever grateful:thumbup:
thanks guys
Old Jun 26, 2003 | 11:56 AM
H-Accord-22's Avatar
H-Accord-22
Duh
They should be able to ajust the toe without any problem related to the camber alignment. For your car, the max rear camber off should be 1.5, so you should need a Metric M10x1.25 pitch by 60 mm long and 7 washers/bolt. the washer type should be 10 mm or 3/8"
Old Jun 26, 2003 | 12:28 PM
A_D's Avatar
A_D
Reset?
ok i went down there and the left camber is off -1.5 and the right is -.7
thanks poohboi but do you think you could tell me what Metric M10x1.25 pitch means
