Gear box
Old Jun 17, 2003 | 05:25 AM
haitred's Avatar
haitred
Default Gear box
What up fellas? I don't if you guys had this problem, but if I come to a stop for a light of parking the whip, when I go into first gear, it takes a few times to go into the gear. I have a Neuspeed short shifter on it and the clutch is factory. Someone told me there was a bolt if I lifted the console, but I haven't checked that yet. What do you guys think? It's pissin me off.
Old Jun 17, 2003 | 05:34 AM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
I somtimes have that problem but it usually because I am going to fast so I have to slow down some.
Old Jun 17, 2003 | 05:54 AM
haitred's Avatar
haitred
I'm not even moving though. It's just getting into first.
Old Jun 17, 2003 | 07:15 AM
vtecaccord01
and this just started?? Change your tranny fluid lately?
Old Jun 17, 2003 | 09:40 AM
haitred's Avatar
haitred
No, it's been happening for a little over a month. I've had that checked a couple of times when I was lazy and had my oil changed and they said the color is chill and so is the level.
Old Jun 17, 2003 | 10:32 AM
Kingseth2's Avatar
Kingseth2
Happens to me too sometimes :dunno:
Old Jun 17, 2003 | 11:44 AM
XprincoX's Avatar
XprincoX
"you wanna die??"
ya happened to me a couple times too. I think its basically becuz theres no syncro for 1st gear or reverse so the gear sometimes doesnt go in. Easiest way to fix it is just pop it into neutral and rev it a lil, then it should go into gear. :thumbup:
Old Jun 17, 2003 | 12:29 PM
skot's Avatar
skot
if its like going into 2nd fine but not sliding into first, try double clutching it then slide it into first. if that doesnt work then start pushing it into first and let the clutch out just enough to engage and spin your gears a bit, it will slide in.
like xprincox said since your not moving your gears wont sync and it may be that they are barely off set.
Old Jun 17, 2003 | 06:33 PM
haitred's Avatar
haitred
Cool, thx fellas. I'll try that, and basically don't sweat it?
Old Jun 17, 2003 | 07:18 PM
XprincoX's Avatar
XprincoX
"you wanna die??"
ya basically that just the way it is, esp for an older car.
