A good fix for hyperblinking
Old May 31, 2003 | 05:37 PM
hype8912's Avatar
hype8912
Dr. Klaw
Default A good fix for hyperblinking
Fixed the hyperblinking turnsignals today with a 10 ohm resistor from the local Rat Shack. You can't use just any resistor. Its got to be these .
Anyway these will get really hot but won't burn up like normal resistors.
Blinkers are back to normal on my 4g accord.
Old Jun 2, 2003 | 11:24 AM
JimBlake's Avatar
JimBlake
Really fast blinking is usually caused by a burned-out bulb. You did check that first, didn't you??
Old Jun 2, 2003 | 01:06 PM
hype8912's Avatar
hype8912
Dr. Klaw
I converted my bumper blinkers to fog lights.
Old Jun 2, 2003 | 02:32 PM
I Like JDM's Avatar
I Like JDM
JDM Spec Tuner
Where do you install them at?
Old Jun 2, 2003 | 04:54 PM
hype8912's Avatar
hype8912
Dr. Klaw
I cut the wires that were going to the front blinker behind the light assembly and just left them there until I found this fix. I piggy backed the front lights off of the side marker lights.
You hook the resistors to the old front blinker wires.
