Tips on mugen DIY grill mod, HELP!!
Old May 18, 2003 | 11:13 AM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Default Tips on mugen DIY grill mod, HELP!!
Aight, I cut the middle bar off, cut the black bracket it mounts to, now comes the fun stuff. Working w/the bondo and fiberglass. I have never ever messed w/the stuff before so im pretty :nervous: I read cryogens diy but i need some visual cue's.
First question is when trying to close the "pac man mouth", do I apply the fiberglass from the back or from the top per the instructions? When I lay the fiberglass down, being that there is a gaping hole in the grill, that part of the fiberglass cloth won't get saturated w/the mixture or should I brush some of it on there? When playing w/the glass, how careful should I be as far as getting it where I don't want it? Would I be ass out if I accidently get it elsewhere on the grill where it's not needed or is it easily sanded away? I'm so paranoid that it's gonna look stupid once I get done, I just can't imagine myself making it look like it was made like that once im done. Bodywork skurrs me.
Old May 18, 2003 | 11:19 AM
Fryd_Up's Avatar
Fryd_Up
rebmeM roineS
lay the fiberglass on the back of the hole, this way when it drys it will be a backing to the bondo and give the bondo something to hold onto and keep it from breaking away. get the whole cloth wet by dipping the entire thing in the mixture.when it drys it gets really hard and stiff and thats what you want. if you get any resin anywhere it'll sand right off, you might have to smooth out and trim the fiberglass with a dremel and some sand paper once its dry too. also while its drying make sure the part at the hole doesnt bend into it, try to keep it flat there. its hard to describe but i hope it makes sense
Old May 18, 2003 | 11:40 AM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
I figured so, just wanted to make sure cause the directions say to lay it in top of the hole, using a rust hole as the example on the container.
dip it? Maybe I was looking at the wrong type of kit but it says to brush on the mixture and it looks pretty thick, almost like a paste. Am I tripping or will the mixture be kinda watery?
if you get any resin anywhere it'll sand right off.
whew! Im bound to get it where it doesn't belongh:
Speaking of a dremel, I am having the time of my life finding the reinforced cut off wheels for it:angry: I ended up using some wire cutters and a soldering iron to cut the grill last nighth: But it worked good, just took a little longer that it probably should have.
I was wondering about that too. I think what im gonna do is lay the glass down, then install the grill back to the black bracket and set it down right side up, that way if it bulges out a bit, the bracket will already be on so I won't have any gaps between the grill and the bracket thanks to a hardened, bulging glass job.
Old May 18, 2003 | 12:38 PM
95AccordEXR's Avatar
95AccordEXR
use bondo instead of fibreglass.
get a piece of window screen and tape it to the back of the hole. Put lots of bondo over and around the hole. Too much is better than not enough.
Old May 18, 2003 | 01:05 PM
Samson's Avatar
Samson
chris is the devil
i backed all the areas i covered in bondo with lots of masking tape, then once the bondo dried, i peeled all the masking tape off.... leaving a nice smooth backing, and used an electric sander to sand it all smooth.... Man was it difficult... time consuming.
Old May 18, 2003 | 01:50 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
They had this mesh looking stuff at the store, had adhesive on the backside, I was thinking about getting some of that but then I thought about it and realized that it's probably not the best stuff to use when working w/small, concave area. Now if I was fixing a rust hole or something, no problem. I think im still gonna use fiberglass and bondo. Using bondo only just doesn't seem too good of an idea, I'd feel alot better knowing that I have some glass on there for the added strenght and support. The part that scares me out of it all is the sanding part, I don't have an electric sander and im just worried that it's not gonna be as clean and smooth as I'd like.
Old May 18, 2003 | 10:09 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
well, I got my products, this is what I got:
3M Emery Cloth(sandpaper)
2ea coarse grit
2ea medium grit
2ea fine grit
Cargroom Fiberglass resin jelly repair kit
Sanding block
bondo
Total cost-$26
