DIY ground system
Old May 13, 2003 | 07:45 AM
kleankord's Avatar
kleankord
Default DIY ground system
here are the old wires:
i ended up having to cut the connector of one end of the oem ground wires so yeah:
here's the ground wire on the right side from the engine mount to the ground:
and here's the old wire and new wire in comparison (old = small scrawny single stranded/new = larger very tightly woven strands):
right side engine mount/mounting points are circled:
wires on right side:
neg terminal battery cables replaced:
couldn't find mounting place for the dist cap or the alternator... I'm thinking the alternator would be the best place possible to mount. when i get my new valve cover in, i'll look more into mounting different locations etc. as of now i have - new batt cables running to chassis and tranny - engine mount to chassis and intake manifold to chassis.
Old May 13, 2003 | 02:09 PM
bucd's Avatar
bucd
Nice pics....have you notice any difference? Like at idle or anything? And if you had more points you replaced or added other then the ones shown.
-D
Old May 13, 2003 | 07:13 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
yeah, the old wires are some grungy lookin' sons a bytches aren't they? I plan on upgrading mine too, it'll make the engine bay look so much better. So besides making under the hood look better, notice any other affects by doing what you did?
Old May 13, 2003 | 07:28 PM
LX4CYL's Avatar
LX4CYL
Cone Basher
Now I think I want to get the HyperGround grounding kit:
http://www.phase2motortrend.com/hypcabnew.html
Old May 19, 2003 | 04:54 PM
96GreenCivic's Avatar
96GreenCivic
Did you have to find new mounting points or did you use the ones already there? Did you buy a kit or did you go the Home Depot route? Was it fairly easy even for a newb?
Old May 19, 2003 | 07:57 PM
kleankord's Avatar
kleankord
i used the factory mounting points, still plan on adding more. i actually bought an amp kit from a car audio store and yes it was very easy
