Headlights will not turn off
Old May 7, 2003 | 03:42 AM
T-bone976's Avatar
T-bone976
Default Headlights will not turn off
My friend has a 3rd gen Accord and the headlights will not turn off. Has anyone heard of this problem?
Old May 7, 2003 | 06:22 AM
Oxygen795's Avatar
Oxygen795
damn son .. never heard of that problem before .. its obviously the switch for the headlights ...
Old May 7, 2003 | 07:58 AM
JimBlake's Avatar
JimBlake
If not the switch, then maybe the headlight relay stuck closed?
This is what DMM's are for...
Old May 7, 2003 | 08:29 AM
AcuraFanatic's Avatar
AcuraFanatic
Probably what happened. Disconnect the battery until you figure out what's happening.
Old May 7, 2003 | 08:37 AM
dantastic's Avatar
dantastic
cx power!
or pull the headlight fuse so u can still drive the car
Old May 7, 2003 | 08:40 AM
AcuraFanatic
I like my idea better. h:
Old May 7, 2003 | 11:25 AM
TJCCARDCO's Avatar
TJCCARDCO
3rd gens are like the F-body trans am's with the pop up headlights, i used to have all kinds of problems with my trans am with that.
good luck.:thumbup:
Old May 8, 2003 | 10:39 AM
T-bone976's Avatar
T-bone976
Does anyone else have a solution?
Old May 8, 2003 | 10:41 AM
decibel_dj's Avatar
decibel_dj
basically u got a short somewhere thats all.. check the fuses, wires and plugs.. if u cant find the problem completely u can always bypass the controls for ur head lights and wire a kill switch (kinda like the lights in ur house) and turn it on/off when need be. its a simple wiring fix until u got time to really dyno the car and see
Old May 8, 2003 | 10:52 AM
T-bone976's Avatar
T-bone976
thanks decibel-dj. I think that may be one of the best signatures that I have ever seen
