92 Accord - Park and drive light problem
Old Sep 19, 2010 | 12:03 AM
Mellumen's Avatar
Mellumen
Default 92 Accord - Park and drive light problem
Hi, I have a light problem on my Honda accord. My probleme is that the park lights and drive lights don't work. Though, my drive lights work when I put the lights in what I call night mode, the mode that you can turn on the big lights, and when I got lights in my instruments. But the park lights don't work at any mode.
Hi, I have a light problem on my Honda accord. My problem is that the park lights and drive lights don't work. Though, my drive lights work when I put the lights in what I call night mode, the mode that you can turn on the big lights, and when I got lights in my instruments. But the park lights don't work at any mode.
If I put power to one of the park lights, all the other (tail lights and plate number lights) works. And it's not the switch (the ting you adjust the light with) because I got steering power out of the switch, so it's not that.
I think it looks like something with the relay, or something around it. The problem is that I don't know witch relay I should look at. So if anyone got a diagram, wiring diagram, or picture of the place with relays, and can explain, it would be great!
Or maybe some here have have a problem like mine, or maybe have an idea or something, it would also be great
Thx for the help
If I put power to one of the park lights, all the other (tail lights and platenumber lights) works. And it's not the switch (the ting you adjust the light with) becuase I got stearing power out of the switch, so it's not that.
I think it looks like something with the relay, or something around it. The probleme is that I don't know witch relay I should look at. So if anyone got a diagram, wiring diagram, or picture of the place with relays, and can explain, it would be great!
Or maybe some here have hade a problem like mine, or maybe have an ide or something, it would also be great
Thx for the help
Old Sep 19, 2010 | 08:34 PM
cruzalekz's Avatar
cruzalekz
broken wire, past the instrument lights. i need a wiring diagram to help you out. sorry. ( not a switch problem in my opinion or fuse)
Old Sep 20, 2010 | 05:56 AM
Mellumen's Avatar
Mellumen
Ok Thx! I have found this wire diagrams, but I'm not good at understand them. Here are they:
http://www.autozone.com/autozone/rep...00c1528005f9fc
Figure 37 to 44 are for Accord 92, maybe you could take a look at it and see if you understand something, and maybe get some ideas of what that maybe is wrong?
I think I have manage to test all the switches and looked at all the fuses, and can't find any problem there...
Thx for the help
Old Sep 25, 2010 | 10:10 AM
cruzalekz's Avatar
cruzalekz
check fuse #23 (15 AMP FUSE). I ASSUME THATS GOOD COZ UR HEADLIGHTS ARE WORKING BUT CHECK IT ANYWAYS.
NO RELAY TO AFFECT PARK LIGHTS. ON THE HEADLIGHT SWITCH CIRCUIT, CHECK SPECIFICALLY RED WITH BLACK STRIPE WIRE FOR 12V WHEN YOUR PARK LIGHTS ARE ON (DO IT RIGHT BY THE SWITCH).
IF YOU DONT HAVE VOLTMETER, BUY JUMPER WIRE AND JUMP RED WITH GREEN STRIPE TO RED WITH BLACK STRIPE...
(YOU ARE BYPASSISNG THE SWITHC) IF PARK LIGHTS LIGHTS UP, CHANGE THE SWITCH. MUST HAVE BAD CONTACTS
