1990 Accord leaking inside
Old Mar 30, 2003 | 05:59 PM
95Supra's Avatar
95Supra
Default 1990 Accord leaking inside
I have a 1990 Accord that has really been a great car for me. The only problem I have with it is when it rains the passenger side floor, rear pass side floor and trunk get really wet. I'm not really sure where it's leaking from, is there a common area on these years to look into?
Thanks
Old Mar 30, 2003 | 06:44 PM
95AccordEXR's Avatar
95AccordEXR
my 88 does that... I dunno why tho.
Old Mar 30, 2003 | 07:08 PM
RY2K's Avatar
RY2K
5 speed
see if where the tail lights meet the car is sealed good i had to silicone mine cause i had the same problem
Old Mar 30, 2003 | 09:26 PM
Kabuki's Avatar
Kabuki
Default Leaks
Do you have a moonroof? If so, you may have plugged drains. Use a water hose and check the seal around the rear window.
Old Mar 30, 2003 | 09:31 PM
kevO212's Avatar
kevO212
damn that sux, sorry can't help
Old Mar 30, 2003 | 10:58 PM
Hondapower10a's Avatar
Hondapower10a
Avocado Green Appliance
my 90 had the same problem after my car was lightly rear ended and had the trunk LID mounted lights replaced. the knock-off non Honda tail lights will leak like a sieve. Tightening the bolts that hold the lights to the trunk lid will help some, as will clear silicone gel (at walmart for about $3.00).
as far as the passenger floor being wet, check the weatherstripping on the door, as the spray from the wheel going down the road will get in there and make the carpet actually squishy. replacing the weatherstipping there will solve the problem, as did with my 90 EX coupe.
If all else fails, check around the moonroof (as previously suggested) and around the front and rear windows (as previously suggested with a water hose).
good luck
Old Mar 31, 2003 | 02:39 PM
95Supra's Avatar
95Supra
Thanks guys...if it ever warms up around here I'll try the hose thing. No on the sunroof.
Old Mar 31, 2003 | 06:02 PM
d21x's Avatar
d21x
Ownz JOO
good luck
yup them red/clears leak like a mofo!!! gotta do that silicone mod. damn red/clears!!!
