Car stuck in park, help ASAP
Old Mar 27, 2003 | 05:04 PM
Fryd_Up's Avatar
Fryd_Up
rebmeM roineS
Default Car stuck in park, help ASAP
So tonight i was driving and honked my horn (airhorns) and then my horn stopped working for some reason. So i pulled into a parking to talk with my friends i honked at and they pulled off and as i sat there i tryed putting the car into drive and it wouldnt go. it's stuck in park. So I ended up having to unlock it manually with the key and then drive it home. I figure the horns my have blown a fuse or something when they stopped working that triggered some security thing. so i just got done taking the bumper off and putting my old origional horns on to try and fix the problem but that didnt work either. So i dont know what the problem is and why the cars stuck. Tranny fluid is fine too. Does anyone know how to fix this or where the fuse for the horn is located (i cant find it) It's a 98 Accord V6 coupe. Thanks
Old Mar 27, 2003 | 05:39 PM
Customlowz's Avatar
Customlowz
Speedbumps Beware
did you check all of your fuses? CHECK THEM TWICE! you probably blew one.
Old Mar 27, 2003 | 05:55 PM
Fryd_Up's Avatar
Fryd_Up
rebmeM roineS
i didnt check ALL, any ideas on what it could be tied in with?
Old Mar 27, 2003 | 06:10 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Well, you'll have to override the tranny. Take off the black plastic surrounding the tranny gate and you'll see a little hole...stick a key in there and you can get it out of park. There's a pic in the owner's manual.
Old Mar 27, 2003 | 06:51 PM
Fryd_Up's Avatar
Fryd_Up
rebmeM roineS
yeah thatsa where i had to look to do that, for a minute i dint that it had one but i found it, thanks though. its going to honda tmorrow.
Old Mar 27, 2003 | 07:06 PM
98CoupeV6's Avatar
98CoupeV6
Sorry, I didn't read that sentence in your post :doh: I read the first couple lines and the last few lines h:
That happened to me once when I was at the mall..scared the shit out of me, but it never did it again. Weird
Old Mar 27, 2003 | 08:25 PM
unisold's Avatar
unisold
you can't move out of park?, you need a new brake switch (10-15bucks) it goes behind your brake pedal. to verify.... turn your car on, and have someone use the brakes...see if your brake lights work.. if they don't, then it is the brake switch, and the car doesn't know you have the brake pressed, so it wont let you out of park... happened to me twice over the past 150k on my 99'... takes 5min to remove & replace
Old Mar 28, 2003 | 08:35 AM
AcuraFanatic's Avatar
AcuraFanatic
Hey, if you had the 4-cyl. 5-speed, this wouldn't happen. :exnbp:
Old Apr 14, 2003 | 10:30 PM
froggy 91's Avatar
froggy 91
usually it's under hood fuse box...a 20 I think
Old Apr 14, 2003 | 10:36 PM
Kabuki's Avatar
Kabuki
Default Fuses
There is also a fuse box on the passenger side of the cabin on the side of the dash, where youcan't see when the door is closed.
