Power wire for Amp
Old Mar 2, 2003 | 06:53 PM
BrentA's Avatar
BrentA
Default Power wire for Amp
I have a '90 accord and ive had a hell of a time running the power cable to the trunk i was just wondering where other 4th genners ran their wire. i couldnot find holes in the firewall so i ran it along the passenger side throught the front fender into my door sill ill post pics later.
Old Mar 2, 2003 | 07:32 PM
Go-N-Low's Avatar
Go-N-Low
This is the drivers side grommet, should be towards the top of the engine bay right on the firewal....
Old Mar 2, 2003 | 07:48 PM
90AccordEX4's Avatar
90AccordEX4
Yep, exactly... same place for me...
Old Mar 2, 2003 | 08:03 PM
BrentA's Avatar
BrentA
its reallly tight
Old Mar 3, 2003 | 10:33 AM
Go-N-Low's Avatar
Go-N-Low
It will fit...I got 1 4 guage and 8 16guages.....Plus room for more....
Old Mar 3, 2003 | 02:29 PM
RY2K's Avatar
RY2K
5 speed
mine's in the same spot
Old Mar 3, 2003 | 03:52 PM
Customlowz's Avatar
Customlowz
Speedbumps Beware
there is another spot to run the wire. let me try to explain this...
peel away the passenger carpet, exposing the firewall. There should be a grommet right in the metal wall. Push grommet, and it should fall out. Now you have a 1" hole to run your wire through!! I accidentaly found it, but I found it to be cleaner of an install that the other side! hope that helps.
Old Mar 3, 2003 | 04:03 PM
MikesCommuter's Avatar
MikesCommuter
As the ACCORD TURNS!
Thats where I ran mine....Altho you will need a Rubber gromet to put in there or you'll get a cool/warm breeze on your left leg as you drive around...I got my rubber grommet at Pep-Boys.
Good Luck
Mike
Old Mar 3, 2003 | 04:16 PM
Go-N-Low's Avatar
Go-N-Low
It really depends on what side you want your wire on...I wanted my RCA's down the passager side and my power wire down the drivers side....
Old Mar 3, 2003 | 06:23 PM
BrentA's Avatar
BrentA
all my power is on the passenger side and would like to keep it that way, the rcas are on the drivers ill look for that grommet Customlowz thanks
