9005 Conversion? What is it
Old Feb 25, 2003 | 06:37 PM
H-Accord-22's Avatar
H-Accord-22
Duh
Default 9005 Conversion? What is it
Before some1 jump off and tell me to do the searches, I did, but on my 28K/56K connection (only half speed kuz old fone line) it took toooo long, 30 mins already (view 4 threads) and haven't found a thing.
What does it mean by 9005 Conversion? Placing 9005 bulbs for low beam? Is it a HID kit we have to buy, or just matter of changing the adaptor to use 9005 for low beam? Will the Light Output better? If so, does any1 got a DIY instruction to how to do it. THANKS A WHOLEEEEEEEE LOT
Old Feb 25, 2003 | 07:10 PM
spinintrax's Avatar
spinintrax
Its engineering some highs in your low beam socket...
http://www.bmwe34.net/E34main/Upgrade/More_light.htm
its a beamer but the mod is the same...
yes, the output will be much brighter, obviously, as you are running a high beam bulb as your low beams. Much luck has been had with the Sylvania Silverstars...and they arent too pricey either...40$ a pair i think?
Old Feb 25, 2003 | 07:26 PM
AadosX's Avatar
AadosX
that link explains it all but heres another just incase...
http://vmac.org/~weston/teg/9005conv/
Old Feb 25, 2003 | 07:45 PM
H-Accord-22
Duh
thanks, i'll try it tomorrow, don't want to buy new headlight.
here's my thought, the guide shows that we make the bulb fit the 9006 adaptor right?
Is it okay if I CUT OUT the 9006 Adaptor, and use the extra 9005 Adaptor and connect the wires together and use the new 9005 adaptor in 9006 place. In another word, I'll be using both 9005 bulbs and adaptor, just running the 9006 wires to the 9005 Adaptor. Won't that help witht he Wattage overload problem?
Old Feb 26, 2003 | 06:54 AM
AadosX's Avatar
AadosX
There isn't really a "wattage overload problem"... why would you go through the trouble of cutting diff adapters and splicing wires or whatever the hell you mean... just cut trim two peices of plastic on each bulb... takes you 5 minutes... and your done.
Old Feb 26, 2003 | 05:43 PM
H-Accord-22
Duh
Thanks, got it done today. I was worrying that the new bulb may draw more current and cause more problems, but I guess it's okay then. I used stock bulbs though. Wht happen if I used aftermarket Super White, they're like 80 watts or something, wil it cause problem to the car?
Old Feb 26, 2003 | 06:36 PM
lilflip's Avatar
lilflip
poop
i doubt it
atm im runnin 9005 silverstars for my lowbeams
Old Feb 26, 2003 | 06:47 PM
H-Accord-22
Duh
Originally posted by lilflip
i doubt it
do you know their wattage rating? thankx
Old Feb 26, 2003 | 08:03 PM
AadosX's Avatar
AadosX
Everyone that has ever done the Silverstar conversion has never had problems with wattage dude... Just do it!
Old Feb 26, 2003 | 09:10 PM
XprincoX's Avatar
XprincoX
"you wanna die??"
But the showoffs are brighter!! :thumbup:
