SRS Light disable?
Old Feb 22, 2003 | 06:54 PM
XprincoX's Avatar
XprincoX
"you wanna die??"
Default SRS Light disable?
Anyone know how to disable the SRS light in the dash? i know its for the airbag, but my bags been deployed so now the light is constantly on. There doesn't seem to be a fuse for it anywhere.. TIA
Old Feb 26, 2003 | 09:13 PM
XprincoX's Avatar
XprincoX
"you wanna die??"
anyone know?
Old Feb 26, 2003 | 09:53 PM
AccordManiac's Avatar
AccordManiac
Korean Member
How about taking out the SRS indicator light bulb??
Old Feb 26, 2003 | 11:36 PM
JonHsiung's Avatar
JonHsiung
u c l a
Go underneath the dash and you will see these two yellow plugs in the picture. Unplug the top plug (smaller one) and then cut a paperclip into two so that you can easily plug it into the connectors, untouched.
Connect the paperclip ends and turn key from 0 to ON. The SRS light will disappear and then within 4 seconds, disconnect the paperclip ends. The light will appear and then you connect it again (within 4 seconds) and the light will blink and then disappear. That or it was on the next disconnect.
Try it out a couple times. I got it on my 2nd try I think.
Old Feb 26, 2003 | 11:37 PM
JonHsiung's Avatar
JonHsiung
u c l a
reading your posts again I stumbled upon a problem. this technique may not work, and probably doesn't work for airbags that actually have been deployed or have a problem. get them reinstalled and reset at the honda dealership. if that thing doesn't work, then sorry dude.
Old Feb 27, 2003 | 06:22 PM
XxRONNxX's Avatar
XxRONNxX
MUGEN Whore!!
Worked for me too. :thumbup:
Old Feb 28, 2003 | 03:20 PM
bonestock's Avatar
bonestock
take out bulb or cut the wire that goes to it.
