head light question brights
Old Feb 11, 2003 | 02:59 PM
ACCORDDUST's Avatar
ACCORDDUST
ChicagoLand Accord Club
Default head light question brights
i know u can take 9005 and put them in the low beams.... but can u put 9006 into the high beams ??
Old Feb 11, 2003 | 03:07 PM
95AccordEXR's Avatar
95AccordEXR
you can do anything you want to
Old Feb 11, 2003 | 03:14 PM
dantastic's Avatar
dantastic
cx power!
:werd: its a free country
:edit: thats ironic, i just quoted a canadian...
Old Feb 11, 2003 | 03:39 PM
ACCORDDUST's Avatar
ACCORDDUST
ok but is it safe to have the 9006 in the 9005 unit ? ?? will it work or blow a fuse
Old Feb 11, 2003 | 04:06 PM
illusion's Avatar
illusion
why in the world would you want to? a 9006 is capped and will have a very very strange beam pattern. As with putting a 9005 in the 9006 socket you'd have to grind off the guides, but it would suit no purpose at all. It's lower wattage, capped, and would just really suck, if you're planning on driving with the inner lights on be forewarned that the DOT SAE guidlines specifiy the low beam being outside of the high beam. But no it wouldn't blow a fuse, it's lower wattage than the high beam, aside from being absolutely worthless it wouldn't hurt anything, other than the bulb you have to modify to make the plug fit.
Again I ask why in the world would you want to do this? That's it, put the bong down and slowly step away
Old Feb 11, 2003 | 04:38 PM
ACCORDDUST's Avatar
ACCORDDUST
lol some kid in my class asked me about it .. he thought it would be c ool to have the whole head light casing all lit up.. u know what i mean .. and by having the 5006 bulds in there it wouldnt be that blinding bc of that cap on the bulb
Old Feb 11, 2003 | 05:16 PM
illusion's Avatar
illusion
he could do what I'm doing with my projector retrofit, just grab 10 super bright white LEDs and put them all over in the headlight housing, should give it a kooooool glow
putting a 9006 in there would still cause glare, it reflects off of the cap and needs a shield to block the lower part of the reflector.
Old Feb 11, 2003 | 05:17 PM
AcuraFanatic's Avatar
AcuraFanatic
Bah, you'd blow something or piss somebody off. Tell him to **** with his own headlight casing.
Old Feb 11, 2003 | 09:54 PM
JonHsiung's Avatar
JonHsiung
u c l a
Don't the superwhite LEDs come out purplish? I bought those damned white LED blinker corners and they look purple and so I thought about buying some HIDs that matched those blinkers.
And lighting up the whole headlight housing would be cool...but you'd probably get pulled over even if the inner parts were dimly lit.
Old Feb 12, 2003 | 04:52 PM
UCIntegra1's Avatar
UCIntegra1
5th Gen Squad... huh???
Default Re: head light question brights
Just use 9005 for both applications. haha, then you can have both on and it'll look the same, as far as intensity goes. I wouldn't recommend keeping both on, tho.... unless you wanna piss off a LOT of drivers on the road.
