Noisy A/C: compressor or bearing?
Old Jul 20, 2009 | 08:26 PM
AmericanPie's Avatar
AmericanPie
Default Noisy A/C: compressor or bearing?
'96 Accord: When I switch on the A/C I get a loud "whirring" noise...so loud it's very noticeable from quite a distance from the car. I can't quite pinpoint the source but air is plenty cold, so compressor seems to be working OK. Would this likely be a bearing in the compressor, an idler bearing that gets noisy under load, or a developing mechanical problem inside the compressor itself? Is any one of these more prone to failure on this model?
Old Jul 21, 2009 | 01:11 PM
flyromeo3's Avatar
flyromeo3
Have you popped the hood open to listen to where its coming from? Look at your crankshaft pulley and see if it wobbles a bit. In my Audi I had the same issue and thought it was the compressor pully but, it ended up being the crankshaft pulley.
Old Jul 22, 2009 | 04:54 PM
AmericanPie
Nope; checked the crank pulley and no wobble.
I'm quite sure it's a bearing and was wondering if others have had a particular bearing in the A/C drive prematurely fail, or if this is a noise the compressor often makes when it's on its way out.
Old Jul 23, 2009 | 12:29 PM
flyromeo3's Avatar
flyromeo3
when did you last replace the drive belts? If the belt (which ever is on the a/c compressor ) is loosing slack it could cause the noise. Is this the original compresser that came with the car?
Would a compressor pully last oer 10 yrs ?
Old Jul 25, 2009 | 04:12 PM
cruzalekz's Avatar
cruzalekz
high pitched is the most likely the bearing
whinning sound should be the compressor
