hot tires?
Old Feb 3, 2003 | 12:43 PM
KMFDM's Avatar
KMFDM
Default hot tires?
ok so i got dunlop sp sport a2 tires on not too long ago and i've noticed that when i drive above 60 or 70 mph, my tires smell like they do in a burnout. also, when i drive hard in the rain for a while and stop somewhere, ive noticed they steam a lot sometimes.
does this happen to other people, or even other people with these tires. it seems to me they are getting too hot?
Old Feb 3, 2003 | 01:39 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
underinflation will cause them to get overly hot and wear wrong... also bad alignment can do it, as there is more friction being put on the tire.
Old Feb 5, 2003 | 03:56 PM
KMFDM's Avatar
KMFDM
thanks, but i just went out and measured them at a cold 32 psi all the way around, and i had an alignment around 4 months ago. anyone else?
Old Feb 5, 2003 | 08:53 PM
vtec94's Avatar
vtec94
look through your tires to see if they are rubbing against somewhere inner fender area.
$.02
Old Feb 6, 2003 | 05:29 PM
KMFDM's Avatar
KMFDM
well there's no rubbing and they clear everything with plenty of room when the car is not moving, so i dont see rubbing being a problem...
Old Feb 6, 2003 | 05:39 PM
F23A4_AcCoRdude's Avatar
F23A4_AcCoRdude
is it all 4 tires that have the same symptoms or just one or two of them?
Old Feb 6, 2003 | 05:44 PM
KMFDM's Avatar
KMFDM
well its just the front two that steam when when they're wet, but i i don't know whether or not the rear get hot as well
