abs light
Old Feb 1, 2003 | 10:03 AM
honda_forever's Avatar
honda_forever
Default abs light
hi all honda forever i wanna ask you alll that know about this problem my abs light goes on in my dash when i start running the car and it doesen't go out what can be the problem? please help me with this problem i have a accord 2 dr 94
Old Feb 1, 2003 | 10:16 AM
95AccordEXR's Avatar
95AccordEXR
First, if you have power mirrors, do they still work? The first time my ABS light came on was because I had a blown fuse. Turned out to be the fuse for the power mirrors. I replaced it and the light went out. Failing that, I would be you have a bad ABS sensor... do a search for how to read the error codes.
Old Feb 1, 2003 | 12:56 PM
AadosX's Avatar
AadosX
Test your ABS and see if it still works...
Old Feb 1, 2003 | 01:00 PM
aux's Avatar
aux
More Black on Black Crime
when you start your car do u hear a buzzing sound?
Old Feb 1, 2003 | 09:42 PM
AcuraFanatic's Avatar
AcuraFanatic
My experiences with older Honda's have been similar. ABS light stays on.
Old Feb 3, 2003 | 09:30 AM
honda_forever
but do you know why it stays on?
Old Feb 3, 2003 | 10:47 AM
dantastic's Avatar
dantastic
cx power!
jump the check engine connector. it will also let you check the abs fault code.
Old Feb 3, 2003 | 11:42 PM
AccordCoup94's Avatar
AccordCoup94
yea, i have the same problem. i used to have this buzzing sound from the engine, i think it was the abs motor, but it dosent buzz anymore after i filled up the fluid, but the light still stays on. anyone know how i can check for the code?
Old Feb 5, 2003 | 05:47 AM
albee's Avatar
albee
I have been installing electronics in my car - sound, cell, driving lights, remote start - and I noticed that the ABS light had come on in the middle of all this. Thanks for your tip, because that is what happened. For some reason the power mirror fuse blew. I replaced it, and so far it has held up. I don't have a decent set of electrical drawings, so I'm at a loss as to how the power mirror is related to the ABS circuits.
Old Feb 5, 2003 | 08:24 AM
95AccordEXR
^_^
