H22/accord swap faq's
Old Jan 28, 2003 | 05:32 AM
wadzii's Avatar
wadzii
fear the dark side
Default H22/accord swap faq's
H22 Swap Faq's
General Swap Info
Use the accord wiring harness and lengthen/modify the harness to fit the H22.
ECU Wiring For Obd1 ecu's
vtec soleniod: Pin A4
vtec pressure switch: Pin D6
knock sensor: Pin D3
Secondary Intake Soleniod: Pin A17
Use accord axles
Buy a manual for the year prelude your H22 came from, the year of the ecu you have and the car.
ex. 97H22 with p13 obd1 ecu into a 94 accord. Get a 97 prelude helms,
a 93 prelude and a 94 accord helms manual. Goto www.helminc.com to get them
Air Conditioning
To keep ac take the bracket off the F22 and put it on the H22 and use the accord compressor
Power Steering
Use the prelude pump and bracket
For 5TH gen Only
Use 92-96 prelude timing belt side mount, keep in mind that you will have to grind it down to fit, and the rest accord mounts
Swap pin A6 with pin A11, the accord is unique from other hondas. those 2 wires control
the o2 sensor heater and egr control soleniod. they are backwards in the accord
The exhaust must be reduced in length and it is reccomended that you get a cat to match the year
header you have. (ex. if you have a 94 h22 header get a 94 prelude cat, etc) the 97+
header is different and the cat isnt the same.
To keep the Powersteering you must have a custom line made using the lower 1/2 of the accord line and upper 1/2 of the prelude line OR use a 97 prelude line
For 4TH Gen Only
Use all accord mounts
The exhaust bolts up to 93-96 Prelude header
No pin swaping is required
No changes need to be made for the power steering hose
obd2 engine in a obd1 car
ex. 97+ H22a4 into 90-95 accord
You must get an obd1 ecu, obd1 injectors and obd1 distributor.
obd1 engine into obd2 car (5 Spd Only)
ex. 93 H22a into 97 accord
Get your favorite obd2-obd1 conversion harness, skunk2, hondata, etc
Move the crank angle sensor wires from the crankpully/timing belt area to the distributor.
Repin the distributor connector using the obd1 plug that should have come on the engine, put
the 2 wires you just moved into the 2 left over pins on the plug.
Internal/External Coil Issues
If your car came equiped with an internal coil then the jdm h22 distributor will plug right
in no problem. However, if your car had external coil then you will have to modify one plug.
The plug you will need to modify is the plug that went to the stock coil. There are is a yellow
and a yellow/black wire, splice those 2 wire together. The green wire is useless, dont worry
about it
What Cap To Use
For JDM internal coil use 00 civic SI or 90-93 accord ex cap and rotor
For USDM internal coil.... DUHH!!! use 93-95 prelude vtec cap
MSD Install
For External Coil equiped cars
Cut the Plug that went to the stock coil off, splice the yellow and yellow/black
wires together, and you will also need to hookup the small red wire from the MSD
to these 2 wires.
The green wire is the trigger, connect it to the White wire on the MSD box or
the negative side of the coil if you are only adding a coil
For Internal Coil cars
You will need the MSD conversion distributor cap.
Take the coil out of the distributor. Run the 2 wires that orignally connected
to the coil out through the hole in the cap, rember which one is negitive and positive.
Connect the positive to the small red wire and the negitive to the white wire.
ApexI VAFC Settings
These settings are different for each car, use these as a baseline and get your car on a dyno
-2 from 0-4800 wide throttle
-5 from 4300-8000 wide throttle
vtec low<>high 4800
Vtec high<>low 4600
Throttle point low 10 high 50
1/4 Mile times for your Hybrid
It really depends on how well you can drive and the condition of your engine. We have seen
anywhere from mid-low 14's to 16's in accords with H22 swaps.
6TH GEN TECH
There isnt much info on 6TH gen swaps. Aperantly the timing belt side mount is an issue as
well as the immobilizer
Transmision Codes
thanks to V4lu3s
m2a4...jdm prelude tranny non-lsd
m2b4...jdm lsd h22a tranny
m2s4...usdm h23a1 tranny/possibly also JDM f22b tranny as well
m2f4...usdm h22a1 tranny
m2ya...usdm h22a4 tranny
m2u4...usdm type sh tranny
Old Jan 28, 2003 | 06:26 AM
AccordSleeper's Avatar
AccordSleeper
Former H22 Accord Owner
Just to add:
A 97+ lude p/s bracket with accord p/s pump and line is another option.
For cat just get universal, anything oem or made to fit will be $$$. I paid $87 shipped for my carsound cat and the install was covered in the swap price since you got to mess with the exhaust anyways welding.
Old Jan 28, 2003 | 07:23 AM
JWise1203's Avatar
JWise1203
Originally posted by AccordSleeper
Just to add:
Anyone have a bracket?? I may be interested in buying it off ya if so.
Old Jan 28, 2003 | 11:28 AM
AccordSleeper
nope bought at the dealer, i think they cost around $85.
Old Jan 28, 2003 | 02:42 PM
SoCalAccord's Avatar
SoCalAccord
Thanks for the info I hope to do this swap in the summer
Old Jan 28, 2003 | 05:08 PM
XxRONNxX's Avatar
XxRONNxX
MUGEN Whore!!
Default for OBD2 96-97 Accords.....
If you use an OBD2 engine on your OBD2 Accord, you can keep it OBD2 for smog legal purposes....no need to convert to OBD1. You can't use a 97+ Prelude ecu because of the immobilizer. However, if you can find a 96 USDM P13 or a JDM P5M ecu, you'll be fine. JDM ecu's do not have the immobilizer. I was able to pass smog and the state ref here in California. 100% Smog Legal Swap! :thumbup:
Old Jan 28, 2003 | 10:27 PM
AccordManiac's Avatar
AccordManiac
Korean Member
I have two PDF files about 4th and very detailed 5th generation Accord H22A swap.. If anyone one it.. E-mail me or find me on AOL.. I collected this swap faq from Honda message board I have no idea which one...and made into PDF files. Thanks to who ever wrote this H22A swap faq..
Old Jan 28, 2003 | 10:35 PM
aux's Avatar
aux
More Black on Black Crime
Thanks for the write up wadzii. :thumbup:
