ABS & TCS Lights on
Old Mar 9, 2009 | 09:29 AM
gurjit923's Avatar
gurjit923
Default ABS & TCS Lights on
Hi,
the ABS, TCS and the triangle with the ! inidicator lights on my car turned on yesterday. I have no idea what that means. Does anyone know what it could possibly be? I'm going to take it to a mechanic on thursday but wanted to see if anyone out there had a clue. i have a 2004 honda accord.
Old Mar 10, 2009 | 06:39 PM
cruzalekz's Avatar
cruzalekz
one of your abs sensors has an open or its just covered up with dirt.
traction control was disabled since it depends on the abs signal to work.
try cleaning up the speed sensors and just drive it, if the code clears then the speed sensors are just dirty. if not, you need a scanner to point you to which sensor is not working.
Old Mar 14, 2009 | 05:04 AM
A-series's Avatar
A-series
v-card member alpha
It could actually be as simple as a fuse, but chances are that cruzalekz is right about it being a sensor.
