maintanence light help!
Old Jan 3, 2003 | 10:21 PM
kleankord's Avatar
kleankord
Default maintanence light help!
anyone know the maintanence light codes? mine's blinking and it would be nice to have the codes so i know what's wrong...
Old Jan 3, 2003 | 10:35 PM
does it blink and then stay solid? or just an endless blinking pattern?
Old Jan 4, 2003 | 11:02 AM
kleankord's Avatar
kleankord
blinking pattern
Old Jan 4, 2003 | 11:13 AM
96JdmAccord's Avatar
96JdmAccord
Im So JDM
IM not positive, But my brother has a 2002 Accord EX, and its does this Blinking thing every something miles so you know it works. I think if you look at your cars manual, it should tell you to hold down some button. Im not sure, might want to ask the dealership....
Old Jan 4, 2003 | 08:53 PM
cwa107's Avatar
cwa107
Yeah, the 6th gen service light will kick on at different maintenance intervals. If you want to reset it, hold down the odometer reset button and turn the ignition to the fully on position (do not start the car). Continue to hold it down for about ten seconds. That should do it. If it's flashing to report a problem, you can probably find the codes by doing a search on http://www.google.com for "ECU trouble codes 99 Accord". You'll probably be able to find a sight that lists the different codes. I would also recommend against driving the car until you figure out what's causing that light to kick on.
