Honda Transmission Fluid and Change Cost ?
Old Jan 15, 2009 | 09:27 PM
irod87's Avatar
irod87
Default Honda Transmission Fluid and Change Cost ?
How much does a honda dealership typically charge for a Automatic Transmission Fluid change?
Would it be cheaper to buy the fluid and have it changed else where?
V6 Auto 6th Gen
Old Jan 16, 2009 | 05:04 AM
flyromeo3's Avatar
flyromeo3
if you know how to unscrew a bolt and let fluid drain out then thats all you need.
Drain and refill. You may have to refill from the dip stick housing as that was the method on the 4cyl.
Drain and refill. No flush.... Call honda and ask what they charge. Dealerships regulate their own pricing.
Old Jan 16, 2009 | 11:26 AM
mista jc's Avatar
mista jc
aka s o l o . c h i n o
Be very sure it's HONDA atf. Don't use any other ATF.
Old Jan 16, 2009 | 04:33 PM
Accord1278's Avatar
Accord1278
It's very easy and pretty cheap. It's actually easier than changing your motor oil. Just make sure get Honda ATF fluid from the dealer and make sure you also get a washer for the bolt. I believe you'll have to purchase like 3 bottles of fluid, of which you'll use around 2.5 bottles. I'm not 100% sure on the amount of fluid you'll need but just ask the parts counter person and they'll tell you exactly what you need and how much.
Remember, just drain and refill! No need to "flush".
Old Jan 16, 2009 | 06:33 PM
irod87's Avatar
irod87
can i also get the washer from the dealership?
Old Jan 17, 2009 | 09:00 AM
Cousin It's Avatar
Cousin It
I also have a 6th Generation V6 auto and my dealership charges $50 to change the fluid.
Old Jan 17, 2009 | 01:19 PM
irod87's Avatar
irod87
[QUOTE=Cousin It;4202675]I also have a 6th Generation V6 auto and my dealership charges $50 to change the fluid.[/QU
did that include the price of the fluid?
Old Jan 17, 2009 | 02:09 PM
Cousin It's Avatar
Cousin It
Yes, it included the fluid.
