Front Speakers not working ....OEM Setup
Old Jan 13, 2009 | 09:26 PM
irod87's Avatar
irod87
Default Front Speakers not working ....OEM Setup
I just purchased a 1999 honda accord coupe and have noticed that only the rear speakers are working. Its a factory radio so I found it kind of odd. Is there anything I should check?
Old Jan 13, 2009 | 10:25 PM
PassportEX's Avatar
PassportEX
Have you check the front rear balance setting on the radio?
Old Jan 14, 2009 | 08:51 AM
irod87's Avatar
irod87
yea that had no effect.
Old Jan 14, 2009 | 07:40 PM
Driver's Avatar
Driver
slow lane cruiser
Next step is to see if the wiring clip is connected, which you should be able to do without taking the door pannel off. Just pull the cover off, unscrew the speakers, pull them out and see if their connected. Perhaps the previous owner just blew them and disconnected them rather than replacing them
Old Jan 15, 2009 | 08:04 PM
irod87's Avatar
irod87
I switched out the deck and they work so not sure what the problem was..... front speakers are partially busted though when i turn it up loud they make a cracklin/popping like sound.
Old Jan 16, 2009 | 12:23 PM
Driver's Avatar
Driver
slow lane cruiser
Well they obviously are going to be replaced I assume, but the crackling is a fried voice coil. Get rid of em and get something good. Good luck with it, crappy speakers really take away from the enjoyment of a good drive.
