lock actuater
Old Oct 21, 2008 | 09:36 AM
fswii's Avatar
fswii
Default lock actuater
Lock actuater going out in 95 Accord. Quotes for repair are around $300. Looks like simple process. Can anyone supply intructions for DIY?
Old Oct 21, 2008 | 03:55 PM
Shounin's Avatar
Shounin
I´ve changed mine just today. The left rear lock became noisy like a “kreeeeeek” sound. I´ve placed a new actuator (not OEM) and it worked 100% like original. But it was done in the repair shop; a simple service; 1 year warranty and total cost around U$45.00. Sorry but I don’t have a diy.
http://cgi.ebay.com/ebaymotors/1x-Po...ayphotohosting
Old Nov 4, 2008 | 02:05 PM
strykernyc's Avatar
strykernyc
LOL mine is making the same noise. some dick try to brake into my car using the rear driver side door and ofcourse i always have the child safety on.
The OEM is $76 and anyone can install it.
Old Nov 6, 2008 | 07:03 PM
500$accord's Avatar
500$accord
Check other threads here. Somebody had a good post that talked about fixing a broken rubber bumper inside the actuator. Mine is bad also. IT is the driver's door on a 96. The dealer quote was well over $100 for the part. Saw it online for as little as $50. I am planning on trying to repair mine first.
Old Nov 12, 2008 | 06:34 PM
trinket's Avatar
trinket
Default how to guide
This link (http://www.accordinglydone.com/forum...php?t=14514)is a very thorough guide to the job. I did my driver door last week-end. It took a little over an hour. It's not hard, you just have to pay close attention to where things are when you disassemble so reassembly goes smoothly. After opening the old actuator up, there are two little rubber bumpers, one of which will be cracked or in pieces. With some solid rubber, and a little whittling, you can fix yours. A new actuator is from $45-80, depending on the car. For my coupe, I had to pay the $80 as I couldn't find an aftermarket one. A source for some accords is: http://www.monsterautoparts.com/HOND...tor_motor.htm?
Good luck,
trinket
