Problem with HIDS/Projectors!!Help!!
Old Nov 29, 2002 | 02:26 PM
plkalra's Avatar
plkalra
Default Problem with HIDS/Projectors!!Help!!
Hello
I tried to install my projector (a6) Hid's (The ones see_fu makes)
on the passenger side is where most of the wires were placed, (being that the battery is here). The socket for 9006, since there's one I plugged that into the pass. side, and then I'm left with the red wire (w/ the fuse on it) and the white/orange colored wire. I put the red one on the positive battery terminal and the other on the negative. There was one wire that goes to the other side to the ballast (that was secured). I checked it all and tried to turn on my lights but no output. Can anyone shed light on this..here are some pics of the wires.
Old Nov 29, 2002 | 04:23 PM
plkalra's Avatar
plkalra
three fuses..i only saw one..where are the others?
Old Nov 29, 2002 | 04:59 PM
plkalra's Avatar
plkalra
the stock headlamp fuses..am i suppose to upgrade the size of the fuse to a more than 20?
Old Nov 29, 2002 | 11:15 PM
Illusion-Lighting's Avatar
Illusion-Lighting
Illusion Lighting
If nothings working, then its either a fuse or the relay.
