How to replace Odometer Backlight?
Old Jul 16, 2008 | 10:39 AM
ao_tenshi's Avatar
ao_tenshi
Default How to replace Odometer Backlight?
Hello, I wasnt able to find other threads that deal with this problem so hopefully we can get some suggestion here. The odometer backlight went out this week on my 2001 Accord... I wasnt sure how difficult it would be to replace it myself. Im a newb so if anyone has any suggestions or can refer me to a tutorial it would be appreciated.
Also it would be fantastic if someone can let me know the replacement bulb model #. Thanks in advance!
Old Jul 16, 2008 | 11:36 AM
Icon Of Sin's Avatar
Icon Of Sin
You can pick up a bulb at a dealer for a couple bucks, or you can get an LED.
http://www.ledautomotive.com/OrderInfo/98-02Accord/ Ive gotten some LEDs for my 01 accord including the odometer from them they look great.
Theres also an install guide on that site that shows where the light is as well.
It doesnt show how to remove the gauge cluster but its easy.
This takes about 10 min.
Drop the steering wheel as low as it can go you dont have to lock it in place.
there are two screws on the top of the plastic piece infront of the gauges remove those two screws.
the bottom part snaps in it will come off with a few tugs.
once that piece is removed there will be 2 screws right below the gauge cluster and two above closer to you remove all 4.
once the screws are out pull the gauge cluster forward a little to get it past the plastic stud things on the bottom that were next to the screws then tilt it twards you so you can un plug the 3 wires in the back.
Once you get those wires un plugged pull the gauge cluster out so you can replace the bulb in the back shown here
http://www.ledautomotive.com/HowToGu...lusterBack.jpg
Its the one the blue arrow is pointing to
Before you put the screws and plastic thing back in make sure it works then your good to go.
Old Jul 17, 2008 | 10:29 AM
ao_tenshi's Avatar
ao_tenshi
Wow thanks a lot Icon Of Sin, going to get a bulb from dealer and try this over the weekend.
Old Jul 17, 2008 | 06:31 PM
Misa's Avatar
Misa
Pic Whore
i believe its a number 74.
i bought a replacement from sears auto.
