Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   Accord (https://www.honda-acura.net/forums/accord-5/)
-   -   96 Accord V6 - sputters & won't start on hill. (https://www.honda-acura.net/forums/accord/285378-96-accord-v6-sputters-and-wont-start-on-hill.html)
ker Jan 31, 2008 10:16 AM
96 Accord V6 if pointed down fairly steep hill sputters & won't start like maybe not getting fuel. I thought fuel injection solved all non-level gas flow problems. Anybody seen this before? As soon as car was rolled to a level position it started. I'll probably replace the fuel filter as it has ~150k mile & I think it may be the original filter. Any ideas?
Fuse Jan 31, 2008 06:29 PM
Are you low on fuel? The filter is on the end of the fuel pump in the tank or on the fuel line i think on the v6s its in the tank. But ya i think you are headed in the rite direction.
You can take out the fuel pump just take up your trunk carpet and take off the plate covering it. Take your cap off to help relive the fuel tank pressure and pull the fuel pump connector , start your car run it till it dies this gets all the pressure out of the line. Then undo the line you push the two tabs. Now i cant remember if the pump is just bolted on the tank or if it has one big nut holding it on (surrounds the out side of the fuel pump). Thats it pumps out. Take a look at your filter and your fuel pick up line also look into your tank for debre. Reinstating be nice to the gasket if you damage it you will set an evap leak code.
If it runs fine at high rpms your fuel pressure is probably fine.
91integrafl Jan 31, 2008 07:02 PM
i thinkl ur lov on gas
Misa Jan 31, 2008 08:19 PM
im not sure about the 96, but my 98 V6 has no filter :o
© 2026 MH Sub I, LLC dba Internet Brands
