need help installing a clock spring for a honda accord
I need help installing a clock spring for a 2001 honda accord
Center your front wheels. Undo the battery wait 3 min to discharge the srs unit. Take off the cover under the center of the steering wheel. Unhook your horn and air bag. Take out the 2 torks bit on the side of the wheel take out your air bag. Undo all the connections under the wheel. Take of the center nut holding on the wheel. Mark the wheel and the center of the steering coulomb so you get the wheel back on the rite spines. Now you do not need a steering wheel just bang one side at a time on the wheel till it comes loose.
You need to take of the top and bottom coulomb cover. I thing the clock spring aka cable reel snaps into place. Remove the cable reel holder. Centering your wheel is very important the spring can only rotate some many times clock wise and counter clock wise. |
Originally Posted by tcguru21
(Post 3738856)
1 Attachment(s)
here:
