93 accord steering question
Old Dec 13, 2007 | 07:04 PM
msand9898's Avatar
msand9898
Default 93 accord steering question
Ok this morning I noticed the steering was a bit off...
I put it in first gear and let off the clutch and automatically the steering wheel rocks left and right by only a fraction of 2 inches???
Whats wrong?
Tires are fine...I dont get it...
Old Dec 13, 2007 | 07:36 PM
Fuse's Avatar
Fuse
Rotate the tire just to rule them out. It could be a bent rim or hub. If it only will do this when you brake it could be a rotor with a lot of run out.
Possibly a bad wheel bearing but you would have a noise too.
Old Dec 13, 2007 | 07:37 PM
nspec_Cd5's Avatar
nspec_Cd5
more than likely it was the ground you were on.
see if happens again. i dont think anything else can cause that.
Old Dec 16, 2007 | 09:07 AM
fstop128's Avatar
fstop128
maybe that your rack is bad. mine does that its an automatic rack is bad.
