Spark plug wires
Old Sep 10, 2007 | 04:03 PM
gearshift's Avatar
gearshift
Default Spark plug wires
1994 EX, I need spark plug wires. What brand name is the best? Is 7mm or 8mm wires best. Thank you in advance.
Old Sep 10, 2007 | 06:56 PM
Snoopy's Avatar
Snoopy
been there done that
stock. ngk or sumitomo, whatever it is.
Old Sep 10, 2007 | 08:19 PM
A-series's Avatar
A-series
v-card member alpha
If you're not sure you can always go bigger as there's no downside to that but in most cases it's not necessary. If your car's stock or anywhere near stock the oems or standard NGKs will be fine.
I got the standard NGKs (come in blue) which are just as good if not better than the wires that came on the car from the factory, plus mine have a lifetime warranty.
Although they're slightly bigger than the stock ones they still fit easily into the brackets on the valve cover.
Old Sep 10, 2007 | 09:04 PM
nspec_Cd5's Avatar
nspec_Cd5
dont get the cheap ones off of ebay. they'll rot faster then u think.
