91 accord overheating
Old Aug 26, 2007 | 02:54 PM
jaymaster3's Avatar
jaymaster3
|R|E|N|E|G|A|D|E|
Default 91 accord overheating
when i am standing at a still with my car on my temperature gauge goes up into the red in less then like 2 minutes. I can bring it down by starting to move again or reving my engine or by turning my heat on full blast. i know this is a problem.. but how serious could this be or wat is the reason this is happening. anything suggestions would help. thnx.
Old Aug 26, 2007 | 03:21 PM
Fuse's Avatar
Fuse
First check your fluid level (cold) then check to see if your coolant fans are turning on.
Old Sep 4, 2007 | 09:46 PM
SaerX's Avatar
SaerX
Had the same problem a while back. A new thermostat fixed things nicely.
-Sale
Old Sep 4, 2007 | 10:02 PM
nspec_Cd5's Avatar
nspec_Cd5
either ur low on fluid, or ur radiator has blocked gullies in it.
Old Sep 8, 2007 | 05:25 AM
deserthonda's Avatar
deserthonda
i agree with fuse .. it sounds like the fans are not working ,, could be the switch at the t-stat housing.. with car running and t-stat open, ( engine warm ) unplug the connector ( 2 wires ) at t-stat housing , jump those wires together if fans come on you found your problem
Old Sep 8, 2007 | 11:24 PM
A-series's Avatar
A-series
v-card member alpha
If fans aren't coming on that needs to be fixed (thermoswitch?) but it shouldn't move into the red that quickly.
Sounds like the thermostat or air in the system... or both.
