h22 problems!! I need answers
Old Jun 23, 2007 | 08:30 AM
h22accord17's Avatar
h22accord17
Default h22 problems!! I need answers
i have a 95 DX Accord i swaped the h22 i used the f22 harness the car runs idles fine but when you give it gas it wonts to choke the engine and it pops out the exhaust i think its a vaccum prob!!! im looking for a jdm h22 vaccum diagram for the car i cant find one im getting eager to drive it its been an on going project ive been working on it in spare time the last two months CAN ANY ONE GIV ME ANY ADVICE???
Old Jun 23, 2007 | 07:15 PM
wedley2's Avatar
wedley2
bboy Wesley West
and you are running the correct ecu? knock sensor hooked up properly?
Old Jun 23, 2007 | 07:17 PM
Fuse's Avatar
Fuse
Vac leak spray break or carb cleaner all over the intake and any vac lines it the engine rpm raises at a spot you spray that would be your vac leak. A cel? Pop out the exhaust this is a good sign of a cam timing problem,ignition timing problem,burned exhaust valves hell about anything.
Old Jun 23, 2007 | 10:12 PM
stereo's Avatar
stereo
make sure your TPS and MAP sensors plugged into the right spots as they are close to each other and switched ...
Old Jun 24, 2007 | 03:30 PM
h22accord17
i went today to work on it my car and i took to vac. hoses re-run them switched them pluged of and all kind of thing i took the plugs out and they had carbon all over them i cleaned those up put them back in and fired and ran fine reved i good time then went back to the same prob!!! i know i got to get new plugs. all the exhaust i have on the car rite now is a header im in the process of get it mad for the car there are two plugs i found that arent hooked up and one is located to the right bottom of the intake the other is above the oil filter will those make the car run so bad i have no clue and if so i have to hard wire them into my harness i am running a p13 computer thanks for the info
Old Jun 28, 2007 | 08:51 PM
stereo's Avatar
stereo
did check the TPS and MAP sensors to see if you crossed the plugs ?
