Stutters below 3000rpm
Old Jun 14, 2007 | 09:00 AM
Topatopp's Avatar
Topatopp
Default Stutters below 3000rpm
I have an 92 accord manual transmission and
the past 3 weeks the car stutters when I drive until the rpm gage goes over 3000rpm then it runs fine with no stutter.
I changed my fuel filter to a new OEM from my local honda dealer same issue
can I have some guidance. thanks...
Old Jun 14, 2007 | 07:06 PM
Fuse's Avatar
Fuse
I think the motor you have has balancer shafts the belt might have snapped? Or maybe you have a misfire under 3000? A cel? Do you know how to check for a miss?
Old Jun 16, 2007 | 11:07 AM
Topatopp's Avatar
Topatopp
I have and 96 f22b motor in the car not the original so..
let me know
Old Jun 16, 2007 | 07:53 PM
stereo's Avatar
stereo
try unplugging the vacuum hose to the EGR valve if the problem is one your EGR ports are clogged...
Old Jun 18, 2007 | 07:01 PM
nspec_Cd5's Avatar
nspec_Cd5
check your motor mounts
Old Jun 27, 2007 | 01:22 PM
Topatopp's Avatar
Topatopp
I also have an code 22 on the ecu
Old Jun 27, 2007 | 03:07 PM
sherwood's Avatar
sherwood
I missed Sean
is it a F22b1? Pretty sure that 22 is a VTEC system malfunction.
Old Jul 2, 2007 | 01:41 PM
AccordRacing's Avatar
AccordRacing
Sounds like a vacuum leak to me .. also check your pcv ..
Old Jul 2, 2007 | 07:13 PM
wedley2's Avatar
wedley2
bboy Wesley West
yea just plug a vacuum guage to the intake manifold when running. should be between 17-22 (i forgot, psi or in-hg)
might want to check EGR. the egr stops after 3000rpm.
Old Dec 17, 2007 | 04:08 PM
Honda_Luvr's Avatar
Honda_Luvr
Sorry to bump something so old but we are having the same problems. We've replaced fuel filter, plugs.
We dont have a vacuum gauge so is there a way to ck the EGR w/o one? He just pulled the hose from it and said it feels like there's no vacuum on it. What exactly are we looking for?
Thanks!
